Re: Wheel Weight Bolts
Posted by John A. on February 14, 2013 at 21:00:59 from (64.128.16.238):
In Reply to: Wheel Weight Bolts posted by IAtractorKid on February 14, 2013 at 13:03:38:
IAtractorKid, Hopefully your wheels are Dished out! and set pretty wide, on 80 inchs or better!
IMO set yourself up to be able to add more wt later on if you need to. Don't shoot yourself in the foot here.
*Use a full lengths of All-thread for this project.
* Need 4/Wheel x 2 = 8 total
Why a full length,, Use 1/2 wt sets on the inside and full 1 piece wts on the outside you should be able to.........
put as many as 4 or 5 / side of a given wheel, 8 to 10 total / side of the tractor
My 966 has a single, 750 lb aftermarket wt on the outside of each rear wheel they have never worked loose! IMO the single all thread is easier to deal with in the long run over the smaller individual wt blots and nuts! Hope this helps.
Later,
John A.
