Re: farmall super c refuses to start
Posted by CNKS on February 17, 2013 at 13:50:05 from (216.144.104.128):
In Reply to: farmall super c refuses to start posted by tyler in sd on February 17, 2013 at 11:24:58:
To summarize the other answers, the rotor is way off, supposed to be 2 o-clock pointed to the #1 terminal, at a minimum your carb has a bad gasket, and make sure the float is at the right height, if you have not cleaned the carb with real carb cleaner, do so. All carburators used or made by IH will flood if you try cranking with the choke closed. Begin with it off and only open for a couple of seconds while cranking. Also when you time the engine with #1 at TDC, and have the rotor pointing to #1, remove the coil wire from the distributer and put the end about 1/4 inch from the nut on the distributer (switch on), turn the distributer to the left (from rear) then turn to the right until you get a spark.
