Posted by tyler in sd on February 17, 2013 at 11:24:58 from (70.198.8.78):
New coil, new rotor, new points, new gas, new plugs and wires, new needle and seat...I believe the engine is timed correctly...I line up the mark on the flywheel with the notch on the front dust cover and make sure that I install the dist. cap with #1 as close to the rotor tab as possible. It is at approximately 9 o'clock. When I turn the tractor over, it does not fire at all and it floods almost immediately, both from the bottom of the Zenith carb and also fuel squirts from the gasket where the carb meets the throat of the manifold. I am not sure what else I should try. Any new ideas or does anyone spot anything I may have missed or done incorrectly? Thanks in advance...
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
