Re: please help clarify gear shifting
Posted by Bob M on November 07, 2000 at 13:12:41 from (192.232.120.194):
In Reply to: please help clarify gear shifting posted by RobertN on November 07, 2000 at 12:33:52:
Lettered Farmall tractor tranmissions are the simple, unsynchronized "sliding gear" type - they're not intended to be shifted while in motion. Normal practice is to start and stay in a gear - only changing gears after coming to a complete stop. However it is possible to up/down shift without grinding while in motion. It just takes the right conditions and a bit of practice. Right conditions are little or no dragging load, and level or downhill travel - so the tractor will coast a few feet while changing gears. With the tractor in motion, the procedure is like this: 1) Step on clutch and shift to neutral. 2) Release clutch and quickly adjust throttle so motor is running at the RPM it will require when in the new gear (this is where the practice comes in!). 3) Now depress clutch and select the new gear. If you do it right the shift occur with no gear clash whatsoever (and if the RPM's are wrong, you'll know it IMMEDIATELY!) 4) Finally release the clutch and tractor on... Once you master the above, try shifting without using the clutch. It takes skillful use of the governor handle, but it works great. Helps if you've ever driven a truck with a 10 speed "roadranger" or similar transmission. The procedure is the same except you're using hand throttle instead of an accelerator pedal to regulate engine speed. Have fun!!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
