Remove No1 sparkplug near the radiator. Hold your thumb over the plug hole while a helper hand cranks the engine. Once you feel pressure against your thumb drop a long plastic straw on top of the piston. Then you watch the straw rise while the helper slowly cranks the engine. Once the straw quit rising your No1 piston should be a TDC on the compression stroke.
Remove the distributor cap and pull the distributor from the engine and rotate the rotor until it points to 2 o'clock and reinstall the distributor.
As been mentioned install the plug wires in this firing order: 2-1 4-3 As the rotor rotates CW.
Make sure you're getting battery voltage to your distributor. It should start now. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
