Posted by The tractor vet on February 21, 2013 at 15:17:52 from (75.19.115.148):
In Reply to: Duals question? posted by FC Andy on February 21, 2013 at 15:05:39:
Well it can be set up with the dish out and the rims set in , now depending on your row crop width that will tell ya what side of the wheel the dogs go on and where your dual hubs will set If your tryen to do a straddle dual set up . And with running a hub mount now you can run the same air pressure on the duals as the tractor. With Clamp on duals running the same pressure i have seen a lot of busted axle clamp bolts . So if your doing a 30 inch row the center of the tire should be 30 inch from the center of the PTO to the center of the tread and thirty inches to the center of the dual .
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
