404 distributor
Posted by RLO on February 22, 2013 at 14:16:44 from (50.33.200.155):
She"s been hard starting & missing (winter in MI) so I took off the dist cap and the coil nodule on the cap was worn flat. Put on new cap & rotor now fires worse (less) that before. Rotor spinning & coil sparking. No spark to plugs. Didn"t put the new points in because the breaker cover is on there pretty good. How does it come off before I break it? Also there is no #1 marked on the replacement cap, but I placed it per the old cap oriented to the clip indent. Does it matter as long as the wires are in the correct order on the cap? Thanks as always for your kind advice. RLO
