Posted by pete 23 on February 22, 2013 at 15:31:50 from (74.47.40.242):
In Reply to: 404 distributor posted by RLO on February 22, 2013 at 14:16:44:
If you are not getting spark to plugs, but getting spark from the coil wire the points are not your problem. It is in the cap and or rotor. If the plug wires are on wrong it may not run but it will still spark at the plugs. The wires can and may have been put on in different orientation as a battery ign unit can be put on any way and timed accordingly. Pull number one spark plug, turn engine by hand until you feel compression on number on cyl, turn until piston is at top or align tdc mark if you can find it, and then install plug wires to align with rotor. Firing order is l 3 4 2 looking at the cap from the rear, side wires plug in they go clockwise. The cover over points can stick bad. Have to get ahold of the two ears and try. Even if you do break it they will run fine until you can find another one.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
