Re: MD power steering advice needed
Posted by mkirsch on February 26, 2013 at 12:09:25 from (64.80.110.74):
In Reply to: MD power steering advice needed posted by IKEin NC on February 26, 2013 at 09:51:40:
Just guessing here but the pump has a drive slot for the magneto on the back right?
Make note of the orientation of the drive slot on the magneto adapter and duplicate that when you install the hydraulic pump. If you match them up the magneto should be timed exactly as before.
For about $25 you can get a compact digital angle gauge from Harbor Freight. Might be worth it to measure the angle of the slot before you pull the old adapter and install the pump.
