I have not had good results pricing ball bearings at the napa stores. Also, realize because a bearing fits does not mean it is the same capacity. Most IH bearings will have loading grooves in them as they have extra balls. Lot of lighter duty bearings do not have that. Probably work just fine in these older not worked hard any more tractors, but, the next thing is all the housings these bearings fit in are also worn so even at best, a new bearig won't last as long as if all parts were new. You will find this most prominent in the brake shaft, differential housings. Then, on the inside axles, IH went to the flat Bower roller bearings but they are not necessary unless you are going to work it long and hard. I would price around but you won't find a package deal, every bearing will be seperate and not all availalble at each bearing outlet. My experience.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
[More Ads]
