Best Source for trans/rear axle bearings/seals ?(Super M)
Posted by mike1972chev on February 28, 2013 at 06:52:45 from (75.149.81.173):
Hey guys,
In the near future I might be rebuilding a Super M transmission and final drive.
Is there a good source other than an IH dealership,if possible to get ALL of these bearings and seals for a total rebuild,or am I going to be going to a bearing and seal house buying these "piece by piece"??? (I would like to be able to get ALL of this stuff at the same location,if possible????? )
Or,is the dealerships the place to go???
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
