Re: Best Source for trans/rear axle bearings/seals ?(Super M)
Posted by CNKS on February 28, 2013 at 17:37:38 from (216.144.104.128):
In Reply to: Best Source for trans/rear axle bearings/seals ?(Super M) posted by mike1972chev on February 28, 2013 at 06:52:45:
I really doubt if you need ALL new bearings. A few will be obviously worn and need replacement. Others will be ok. If you question some of them, take it to a bearing place and compare it to a new bearing, does not have to be exactly the same. I have done that more than once and decided the new one wasn't any better. On a much smaller scale I replaced all the bearings and seals in my Super A trans and finals mainly to see if I could quiet the transmission. It did help some, but still has the traditional noise. I replaced all the bearings in the top shaft in my Super M mainly because I needed the pilot bearing, and the others on that shaft were easy to get to. I had no desire to get into the differential, etc, because it was quiet. To answer your question --- With very few exceptions any good bearing place can get all your seals and bearings--however, as Pete mentioned some of the IH bearings, along with an occasional seal are better from CaseIH than the bearing stores.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
