I would suggest installing a Pertronix Igniter ignition replacement system for about $90.00. Very easy to do and now you do not have to worry about the points and condenser. This way the ignition system will give you a very good spark. Only thing additional is be sure your coil will produce a good ignition spark. Do not use anything other than a stock coil with this system. You can check the coil by taking the wire going from the coil to the points and very quickly touching it to ground and then removing it from the ground (opening and closing the circuit), just like the points would do. If you get at least a 1/2" spark out of the coil wire (being held with this gap from a good ground), then the coil should be fine. Boy does this help my 300 with starting in all types of weather.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
