Posted by Ben Pung on March 02, 2013 at 17:06:08 from (70.194.128.38):
Hi all. I have an IH 300 Utility (1956) that I have a strange issue with. It has never liked to start in the cold (40 and under). When I go out and try to start it, it will run for just a second and stall out. When I crank a second time, the top half of the carb gets frosty and gas starts dripping out of the bottom of the carb. I figured out this winter that if I run a hot air dryer on the carb for a few minutes, then blow some warm air into the air intake as I"m cranking it, it generally starts right up. Today I did exactly that and headed out to get my truck out of the mud (I"ve had a tough day). The tractor ran fine and normal all the way out to my truck. It was up to operating temperature by the time I got there. I chained it to my truck and started to lift the bucket and it stalled out. Now it won"t start again. I crank it and gas leaks out of the bottom of the carb. Blowing warm air on it does not good now. I checked my plugs and they don"t appear to be getting gas (not wet at all). Any ideas what would be wrong with it? All I can think is to take the carb apart and try to clean it, but I want to be sure I"ve tried all other options before I go down that road. I have a hard time finding parts for this thing and I don"t want to mess up the carb gaskets unless I"m sure it"s necessary. Thanks.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
