Re: 300 TO bearing carrier
Posted by D Slater on March 03, 2013 at 12:15:24 from (184.15.17.95):
In Reply to: 300 TO bearing carrier posted by Bkpigs on March 03, 2013 at 10:54:04:
Think the one with the grease fitting was changed sometime. F-300 started out with no grease fittings and after IH had some complaints about the sleeve getting dry and causing operating problems the grease type was added. Also put grease to the bearing. IH made the change on farmall 350 seven hundred and something. Don't remember the exact number.
