Posted by pete 23 on March 03, 2013 at 14:14:57 from (74.47.40.242):
In Reply to: Hydro 86 posted by JGB on March 03, 2013 at 11:16:53:
Probably both, but pump is inside, pretty much integral to hydrostatic drive on those models. There are other possibilites so what I would do is cap off the two small outlets with 1/4 in steel lines coming off top of control plate on side of hydro. Use steel caps. This will eleminate all external valves to see if it still acts up. You will not have a foot n inch pedal though with those capped off so be careful. Speed ratio lever will be only control of hydrostatic drive speed or stopping. If it works the same capped off I would test servo pressures though before I tore into the hydro. If it works fine capped off then you start looking at the control capsules and foot n inch valve.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
