Is the power steering also operated with this pump? If so, it has priority and will tap off about 3gpm. I can tell by the plumbing on my 240U that it was operated by the live pump at one time, but PS has been added and then whoever had this tractor before added a crank driven pump and separate valves on the loader... no longer uses the built in valves, except for the 3 point. My guess is the loader worked fast enough before PS was added, but PS was a big help with the loader.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa
... [Read Article]
Latest Ad:
[More Ads]
