Posted by El Toro on March 04, 2013 at 04:12:01 from (108.3.218.181):
In Reply to: 3588 running hot posted by Doug Wi on March 03, 2013 at 19:21:51:
Make sure the thermostat is opening fully. Put it in a pan of water and heat it. Also check your water pump. Make sure the belt is tight. Take a look at the impeller to make sure it isn't worn or may not be rotating. Touch the lower radiator hose lightly when the engine appears hot to see if it's hot. Did you have an overheating problem before the radiator repair? Tubes clogged in your radiator will stop circulation. Hal
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
