3588 running hot
Posted by Doug Wi on March 03, 2013 at 19:21:51 from (74.117.241.1):
Was plowing with the 2+2 this fall and the temp wanted to run right up on the red line. Rad has just been off and repaired so it is clean.Checked the coolant level and it was ok . This one has the optional coolant filter. In true redneck tradition, I have never changed it.In my understanding that isn't a full flow filter so shouldn't cause the running hot. causes; bad thermostat? bad gauge? . When I checked the coolant level , it wasn't boiling over but did seem hotter than normal.This was just before thanksgiving in N Wis so air temp wasn't a factor. Were should I start? thanks
