Re: slow front loader on 350 utility
Posted by mkirsch on March 04, 2013 at 05:27:11 from (64.80.110.74):
In Reply to: slow front loader on 350 utility posted by GP Hansen on March 03, 2013 at 13:53:24:
How slow is slow?
I don't know of any universal definition of slow. Slow is an opinion. What's slow for one is dangerously fast for someone else. Define slow please.
Are you running the tractor at full throttle to get maximum pressure and volume?
Was it always slow? Did it work fine then suddenly get slow?
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
