Re: slow front loader on 350 utility
Posted by GP Hansen on March 04, 2013 at 08:37:15 from (71.217.207.235):
In Reply to: Re: slow front loader on 350 utility posted by mkirsch on March 04, 2013 at 05:27:11:
It"s noticibly twice as slow as the 3 point or tipping the bucket. It would take 10 - 15 seconds to raise it to full height at half throutle empty. It"s been slow since I"ve had it.
The 3 point appears to be an after market one but works fine.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
