Posted by RPM1941 on March 04, 2013 at 15:56:36 from (173.23.76.185):
In Reply to: 3588 running hot posted by Doug Wi on March 03, 2013 at 19:21:51:
I would guess first item would be faulty temp sender, dash gauge next, these are high failure parts on 86/88 series, the thermostat can just be removed for a test, water pump not as prone but if you can feel any wobble by shaking fan blade & I mean very slight wobble the water pump main bearing is failing, blow or wash out radiator fins, also check anti freeze for foaming, wont cool if it is, try straight water just as test. This is from 47 years in IH/CNH service.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
