The use of a test light to set the spark timing is as follows. With the ignition on, and the test light hooked to the coil connection to the distributor, turn the distributor in the direction from rotor rotation till the light goes off (points close). Now turn it opposite rotor rotation until the light just sputters between on and off. Lock it down, and turn off the ignition. Don"t leave it on more than a couple of minutes! If it is on compression TDC, the rotor is now pointing to #1 Plug (front of engine) Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
