Re: '49 Farmall Model C gov to carb adjust
Posted by Janicholson on March 07, 2013 at 08:29:41 from (199.17.6.160):
In Reply to: '49 Farmall Model C gov to carb adjust posted by mpbarber on March 07, 2013 at 08:21:41:
That linkage cannot be an inch wrong.
If the throttle hand lever when moved also moves the governor to carb lever, and the carb throttle lever on the carb is turned so it is wide open as well, the adjustment should be expected to be a half hole or so at most.
an inch is almost the entire travel of the rod.
Make sure the carb is held wide open, and the throttle hand lever is full fast position.
Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
