Posted by Patrick HMD on March 08, 2013 at 18:18:24 from (75.0.231.0):
I had decided to use straight 30 wt. Seems like the general consensus here is to use non detergent for fear of breaking some crud loose with high detergent therefore clogging up some oil passages and causing problems there. So I decided to give it the benefit of the doubt and I went and got some Traveller 30 wt. ND from Tractor supply with that in mind.
Now I'm reading the lable and it says the ND has no additives, and is not suitable for use in most gasoline powered automotive engines built after 1930. It goes on to say that it might cause equipment harm. So what's a feller to do.
I have no prior history of what kind of oil was used in it's past life. I did drop the oil pan, and the bottom of the pan had very, very little sludge buildup. Also the exposed guts looked very, very clean. Right now the M purrs like a kitten and dosen't smoke at all. So again, what's a feller to do?
TIA
Patrick
'49M
This post was edited by Patrick HMD at 18:21:05 03/08/13.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
