Re: First oli change for the 49M
Posted by S2710 on March 09, 2013 at 10:07:41 from (98.143.227.89):
In Reply to: First oli change for the 49M posted by Patrick HMD on March 08, 2013 at 18:18:24:
Pat just run a good grade of oil in her and it will be fine. Years ago I bought a M that was very dirty. The valve cover had so much junk in it that you could see marks where the rocker arms were moving in the cover.I cleaned the top off with diesel fuel and droped the pan and cleaned it out. Put it back together and filled it up with ATF and ran it at about half throttle for a half hour and drained it and did the same thing again and then put 15-40 diesel oil in it and never had a problem.
Bob
