Re: Re: Re: Re: Re: Marvel Schebler Carburetor for IH tractor
Posted by Gene on November 10, 2000 at 20:59:29 from (205.188.192.43):
In Reply to: Re: Re: Re: Re: Marvel Schebler Carburetor for IH tractor posted by T_Bone on November 10, 2000 at 15:21:27:
T Bone - I appreciate the tip. Will check out the compression. I did some time back, but will do it again. The carb seepage of fuel has me pretty puzzled, as I had taken a hint from one of the forum members that suggested I check the fuel level in the carburetor while it was running and also when it was stopped. I did that and it never was high enough that it would spill over into the other chamber where the weep hole is. I even took the carburetor apart, set it on a workbench and poured fuel in the carb and checked for a possible crack in the carb housing. Didn't see any seepage across. Thanks for the tips and will check it out.
Post A Followup
: Re: Re: Re: Re: Re: Re: Marvel Schebler Carburetor for IH tractor
