Re: Disconnect Transmission Countershaft Coupling
Posted by farmallboy15 on March 09, 2013 at 18:40:16 from (198.228.228.173):
In Reply to: Disconnect Transmission Countershaft Coupling posted by F4RM@11 on March 09, 2013 at 18:36:25:
If it's the same as an h, which I believe it is, there should be
two cotter pins you remove then slide the collars in and the
coupling comes out.
