Re: Disconnect Transmission Countershaft Coupling
Posted by Janicholson on March 09, 2013 at 21:44:24 from (74.60.94.18):
In Reply to: Re: Disconnect Transmission Countershaft Coupling posted by farmallboy15 on March 09, 2013 at 18:40:16:
It is much shorter, and has no pins. Jim
