Re: Farmall C-263 ignition
Posted by Elder Al on March 09, 2013 at 21:43:34 from (216.228.33.124):
In Reply to: Farmall C-263 ignition posted by Elder Al on March 09, 2013 at 14:42:43:
The dist. came off a 560 Farmall that had an occasional miss. I thought it was a sticky valve until it out of the blue started missing, backfireing and just being bad. After gas was checked, & carb messed with, nothing helped. Dist cap showed rotor to be hiting- leading to checking for slack in rotor shaft..about .050 movement. To verify i took dist out of my 656 and stuck in. In spite of being wrong advance, the 560 now runs without any miss, has excellent throttle/governor response and good power. Just how criticle is this curve if not pulling hard? Thanks for the above comments.
