Re: Farmall C-263 ignition
Posted by Janicholson on March 09, 2013 at 21:51:57 from (74.60.94.18):
In Reply to: Re: Farmall C-263 ignition posted by Elder Al on March 09, 2013 at 21:43:34:
The advance plate has slots on it that limit the total advance. The weight of the weights, and the springs tension rate determine the advance relationship to the RPM. When making a new bushing, be sure to measure the shaft accurately. A worn shaft will still wallow the bushing, and you cant get the gear on a smaller (turned down) shaft.
Sometimes the bushing can be made longer to operate on a new place on the shaft. Make sure it does not interfere with the other components. Jim
