Got the Super A cranked - OIL LEAKING from filter HELP!!!
Posted by GRAPE-DRANK on March 12, 2013 at 08:36:30 from (173.53.88.194):
After painstakingly building this motor I got it cranked on the first try. Oil is pouring out of the filter. I have repositioned it and tightened it down I was able to slow the oil, but I can't stop it from leaking. What am I doing wrong?
The block is from a 130, I think the oil cap is from the Super A. It has a filter and a rubber gasket, I checked and rechecked. There is no better way to fasten it then what I have done.
What is going wrong here?
Here's a vid of the first crank:
http://www.youtube.com/watch?v=Y11zNz2wNtY&list=UUmV4Ud6hHHOGnlasYBH6o3w&index=1
