Thanks MNGB! I set the timing and set the valve lash today. If it were not for the wine of the hydraulic pumping you wouldn't be able to tell the engine was running (at idle) from the other side of the garage.
I had to use brake clean and a pick, but I got some residue out of the ring where the gasket goes. Oil doesn't pour out, but it does permeate through. I think that's going to be as good as its going to get.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
