IHC 574 flywheel
Posted by redrob1546 on March 13, 2013 at 12:30:51 from (71.50.118.117):
Dose anyone know what the dimension is supposed to be from the clutch surface to the cover or pressure plate mounting surface of the flywheel on a 1972 IHC 574 diesel engine. I think that the clutch surface on mine has been turned and the outer part was not, when I put in a new rebuilt clutch, the bolts were tight in less than 2 turns from finger-tight.
