Re: IHC 574 flywheel
Posted by jimb2 on March 13, 2013 at 14:53:33 from (99.241.76.141):
In Reply to: IHC 574 flywheel posted by redrob1546 on March 13, 2013 at 12:30:51:
Hi Redrob, these are the specs that I have:
Flywheel settings for 574:
the flywheel pot depth must be restored to 36.6 mm. this is measured between the flywheel wear face and the clutch cover mounting flange around the flywheel rim
pressure plate face height to mount 31.65 mm finger height 81 mm
fltwheel maching clearence 1.443 inch
