That "single wire" alternator output wires up to the Load (NOT battery/starter) side of the ammeter, the same terminal that feeds battery voltage to loads such as lights and ignition etc. The other Supply side of the ammeter gets to the batterys hot ungrounded post, often by a wire down to where the big battery cable attaches to the start switch/solenoid. Often then theres ONLY ONE wire on the ammeters Supply side (to battery/starter) and maybe two (Alternator and wire to light/ign switch) on the Load side....
If all is wired right yet it drastically continiues to overcharge (keeps battery at say 15 volts all the time) Id say the Voltage Regulator is bad and that will cook the battery...
On the 10SI 3 wire units that one small terminal was used to sense battery voltage, maybe the alternator isnt sensing true battery voltage
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
