Re: Single Wire Alternator
Posted by K-Mo on March 16, 2013 at 04:05:48 from (66.43.226.235):
In Reply to: Single Wire Alternator posted by 5 Forward on March 15, 2013 at 18:13:37:
You don't say what the range of your ammeter is. If you have a 30 amp or less gauge, you can expect it to peg after start up. I use a 60 amp. Depending on the output rating of the alternator, it may still peg initially, but should soon tapper back. Alternators have a much higher output the the old generator. The smaller common Delcos are about 40 amps.
If voltage on a fully charged battery exceeds 15 volts, the regulator is probably bad.
