M clutch removal
Posted by Patrick HMD on March 22, 2013 at 03:01:44 from (75.9.214.72):
Now that I dropped the belly pump I'd like to clean up all the oily dust off the clutch assembly. The service manual clearly explains how to collapse the springs with 3 of the 6 bolts before removal. Only problem is, there is no tapped holes in the pressure plate to suck in the springs. Will there be a problem if I don't collapse the springs before removal of the clutch assembly? Is there another way to skin this cat? This is my first time attempting this.
The parts manual clearly shows the 3 tapped nubs on the pressure plate, but there's none on mine. Why?
TIA
Patrick
'49M
This post was edited by Patrick HMD at 03:12:38 03/22/13.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
