Re: M clutch removal
Posted by rustyfarmall on March 22, 2013 at 11:24:27 from (216.248.71.226):
In Reply to: M clutch removal posted by Patrick HMD on March 22, 2013 at 03:01:44:
The tapped holes are there, but they might be smaller than expected. Aftermarket replacement parts don't always follow the rules. The pressure plate DOES need to be collapsed if you are doing the job without splitting the tractor. You will never get the driveshaft out otherwise. (Been there, done that)
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
