David Bowers said: (quoted from post at 17:07:26 03/27/13) Trying to find hydraulic pump seals for 350 Diesel. The seal is marked TPHP1-3-89 C/R. My parts book does not show this style of seal. It's for a 3/4 shaft, .40 thick and 1.82 outside.
David 602 930 6501
I'm just guessing, but does TPHP=Thompson Power Hydraulic Products?
Thompson and Pesco made the original hydraulic pumps for 300-450 tractors. C/R is Chicago Rawhide, a seal manufacturer, and is still in business. See if they offer a cross to the old seal.
It is possible that this is a proprietary seal made for this application exclusively for the pump mfr. and/or IHC. If that's true, you might only be able to find one from the pump mfr. or CIH. I've run across some bearings that the bearing manufacturer will only supply to CIH and aren't crossable to anything else without serious modification.
AG
This post was edited by AG in IN at 13:14:02 03/27/13 2 times.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
