Re: Hydraulic pump seals 350 Diesel
Posted by David Bowers on March 27, 2013 at 20:37:01 from (68.231.58.10):
In Reply to: Re: Hydraulic pump seals 350 Diesel posted by AG in IN on March 27, 2013 at 12:46:21:
Thanks for the reply, you're right SKF bought out Chicago Rawhide 17 years ago. Talked with Cathy at 224 535 4641 and she sized a seal SKF7661. It's a single sided seal, not like the one TPHP1-3-89 C/R. She said they made the seals in those days by hand and the second side was to hold the spring in place. Found the new style here in Phx and will try to install tomorrow. Thanks for the help.
David Bowers 602 930 6501
