Re: Hydraulic pump seals 350 Diesel
Posted by D Slater on March 28, 2013 at 06:04:13 from (184.15.9.188):
In Reply to: Re: Hydraulic pump seals 350 Diesel posted by D Slater on March 28, 2013 at 02:51:25:
Found some old notes I have from working on the pumps in the past. TPMP1389 is IH 363781R91 or CR8842 at one time. That info is probably over 10 years old.
Disregard the rear seal mentioned in the other post.
Looked at some old seal boxes I saved and it looks like one seal I used for TPHPl 3-89 is national 471137 .875X1.828X.375. Front seal Thompson pump.
Also found a CR8842, .875X1.828X.375. Don't remember which one was the best.
This post was edited by D Slater at 10:08:41 03/28/13 2 times.
