Re: H Charging Problem
Posted by Janicholson on March 29, 2013 at 17:09:34 from (74.60.94.18):
In Reply to: H Charging Problem posted by Doug Kieta on March 29, 2013 at 13:59:29:
Good high quality Voltage regulators are difficult to find. Cleaning between the contacts with very fine (600) paper can make them work. A generator with a internally shorted (not to ground) field will put high strain on a VR. Current in the field circuit when F is hooked directly to ground through a good amp meter (not the gauge) you should see about 2 to 3.5 amps or so with it running at 3/4 throttle. If more, the field may be bad. Jim
