Re: H Charging Problem
Posted by gene bender on March 30, 2013 at 16:46:25 from (67.55.226.151):
In Reply to: H Charging Problem posted by Doug Kieta on March 29, 2013 at 13:59:29:
Did you get the correct regulator listed for the Delco-Remy tag on the gen. And it the gen anoriginal one that came on the tractor or a replacement. Car Quest has regs that are built here in the US not imports like lots are ive been using them without any problems. Lots of listings have a one size fits all.
