Re: Farmall 400 Brake Disk
Posted by D Slater on March 30, 2013 at 18:55:16 from (184.15.9.188):
In Reply to: Farmall 400 Brake Disk posted by Chuck McDonald on March 30, 2013 at 18:31:03:
Look close on the back edge and you can find some slots to use to pry it out. Needs to come out pretty even. Has a oring on it and fits pretty tight. Or put a long 5/8 fine thread bolt in the pinion shaft end hole and with something heavy to slide (or slide hammer or other) and hammer the pinion shaft out and the plate will come out also. Inspect the shaft and bearing and just slide it back in if good. Seal is easy to remove and install with the plate removed. May also need the oring if damaged.
