Farmall 400 Brake Disk
Posted by Chuck McDonald on March 30, 2013 at 18:31:03 from (208.103.220.66):
Hi All and Happy Easter!
Woking on my Farmall 400 Diesel and am unable to remove the fixed brake disk closest to the rear end housing.
Need to remove to fix leaking oil seal on brake shaft. Are these attached to the housing by bolts on the inside? Do I need to remove the top of the rear end/transmission to get to them?
Thanks
Chuck McDonald
