Posted by Bob M on March 30, 2013 at 18:59:00 from (67.240.171.136):
In Reply to: Farmall 400 Brake Disk posted by Chuck McDonald on March 30, 2013 at 18:31:03:
Chuck - The inner disk/seal retainer is a tight slip fit into the main housing. Look carefully around perimeter of the disk - there are several (4?) spots where the disk is chamfered (wire brushing the perimeter helps make the chamfers evident).
To remove the disc simply insert a chisel into one of the chamfers and give it a few taps. Now move the chisel to the chamfer 180 deg opposite and repeat. The disk should begin to separate from the tranny.
Once it gets started, a pry bar or large screwdriver will lever the the disk the rest of the way out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
