Posted by RTR on March 31, 2013 at 09:55:21 from (74.248.177.216):
In Reply to: Farmall 140 questions posted by Eric Blazek on March 29, 2013 at 20:09:50:
Sounds like an OLD mixture of Antifreeze and water leaking. OLD fluid of that type would have a distinctive smell, and when a leak happens, it could leak enough to make a pool under the tractor. I'm going on a whim, but I presume you don't know Alot about tractors. Pictures would be great if you could get them, and then we could help you better. There are only 4 fluids in that tractor, Antifreeze/Water Mix (front), Hydraulic and Motor Oil (engine area), and 90 weight gear oil (rear area). The gear oil is similar to motor oil in sight but much, much thicker.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
