Re: Tractor Repair
Posted by ih1566 on April 01, 2013 at 17:31:30 from (98.132.231.144):
In Reply to: Tractor Repair posted by Frank Castro on April 01, 2013 at 16:38:53:
ok well ..start at plugs,if its not then then check and see if you can see spark at the points, then if no spark there then check and see if you have power to your coil then check if you have juice on both sides of switch when switch is on.. proccess of elimination..
ih1566
