Tractor Repair
Posted by Frank Castro on April 01, 2013 at 16:38:53 from (72.209.208.37):
In need of tractor mechanic near northern virginia. I have an IH 444 aprx. 1970. Gas. No power to spark plugs. Replaced points, coil, distributor cap and spark plugs. Tried everything. Seems no power going to distributor. I had 2 people look at it so far. Time for a mechanic. Any recommendations?
